Security Compliance
Self-Led Project Plan for Patch Manager
This article provides a step-by-step guide for self-led onboarding of SolarWinds Patch Manager. It includes installation, integration with the SolarWinds Platform, configuration of WSUS and SCCM settings, patch approval and deployment, third-party updates, compliance reporting, alerting, and best practices to help you streamline patch management, maintain system security, and ensure compliance efficiently.
Installation & Setup
Confirm Patch Manager Installation
Patch Manager Installation Guide
Verify SolarWinds Platform Integration
Integrate Patch Manager with the SolarWinds Platform
Configuration & Settings
Configure WSUS Servers
Add and configure WSUS servers for centralized patch management.
Add a WSUS server
Configure SCCM Integration
Integrate with Microsoft SCCM for extended patch management capabilities.
Integrate Patch Manager with SCCM
Set Up Patch Manager Accounts & Roles
Assign user accounts and roles for patching tasks and access control.
Patch Manager Security Roles
Patch Management Operations
Import and Publish Third-Party Updates
Download, approve, and publish third-party patches via Patch Manager.
Third-Party Updates Setup
Schedule Update Approvals & Deployments
Automate approval and deployment of Microsoft and third-party patches.
Schedule Patch Tasks
Create Patch Management Jobs
Build and schedule recurring jobs for scanning, approval, and deployment.
Manage Patch Manager tasks
Monitoring & Reporting
Run Patch Compliance Reports
Generate built-in reports for patch compliance status across endpoints.
Patch Compliance Reporting
Create Custom Reports
Build custom patch reports for specific nodes, groups, or compliance rules.
Customize an existing report
Alerts & Notifications
Configure Patch Notifications
Set up email notifications
Configure the Patch Manager email settings
Best Practices & Enhancements
- Backup Patch Manager Configuration
- Export and save configuration settings before major changes.
- Use Approval Rules
- Automate patch approval workflows based on criteria.
- Validate Environment Compatibility
- Ensure compatibility with WSUS, SCCM versions, and supported OS platforms.
Notes
- This plan is designed for customers who prefer a self-paced onboarding experience.
- For assisted onboarding, refer to SolarWinds Deployment Services.
- For troubleshooting, contact SolarWinds Support.
