Self-Led Project Plan for Enterprise Operations Console
This article provides a step-by-step guide for self-led onboarding of SolarWinds Enterprise Operations Console (EOC). It includes installation, integration with the SolarWinds Platform, configuration of sites, dashboards, and maps, cross-site monitoring, alerting, reporting, and best practices to help you centralize visibility, streamline operations, and enhance monitoring efficiency across multiple SolarWinds Platform deployments effectively.
8/18/2025 4:47 PM
8/18/2025 4:47 PM
Installation & Setup
Check System Requirements
Ensure the server hosting EOC meets all required specifications.
EOC System Requirements
Confirm EOC Installation
Ensure EOC is installed and ready for configuration.
EOC Installation Guide
EOC Scalability Engines
Additional Web Server (AWS) is available for EOC
Install scalability engines for EOC
Monitoring & Settings
Add SolarWinds Platform Sites to EOC
Create and add SolarWinds Platform environments to EOC’s consolidated dashboards/views.
Configure EOC Views & Dashboards
Edit and add dashboards, tiles, and filters to customize your environment summary.
Configure EOC Views
Customize Environment Summary
Manage Widgets & Summary Pages
Add, remove, and filter widgets to focus on select SolarWinds Platform sites or entities.
Add or Remove Widgets
Quickly analyze trends, troubleshoot issues, and identify root causes using flexible, customizable visualizations
Performance Analysis (PerfStack) charts in the SolarWinds Platform let you visually correlate historical and real-time performance metrics from multiple monitored entities (e.g., nodes, applications, interfaces) on a single timeline.
Performance Analysis Charts
Maps
Create and Import Maps
EOC Maps let you visually represent and monitor your distributed environments by importing maps from the SolarWinds Platform sites into EOC. You can organize and display multiple imported maps on EOC dashboards to gain centralized, visual situational awareness.
Build or Import Maps
EOC Maps Overview
Alerts & Actions
Review EOC Alerts
EOC consolidates active alerts from multiple SolarWinds Platform sites into a single view, allowing you to monitor, filter, and manage cross-site alerts centrally for faster triage and response.
EOC Alerts
Reporting
Review Out-of-the-Box EOC Reports
Access and review prebuilt EOC reports.
EOC Reporting
Create Custom EOC Reports
Build reports filtered by site, group, or entity type.
Customize Site Reports
Best Practices & Enhancements
  • Backup Configuration – Backup EOC settings before major changes.
  • Use Custom Properties – Tag and organize SolarWinds Platform sites, nodes, and resources with custom properties.
  • Validate Environment Compatibility – Ensure EOC is compatible with SolarWinds Platform versions and APIs.
Notes
