Security Compliance
Script parameters for group membership and file server alerts not working in ARM
This article describes a known issue in ARM where certain scripting parameters for group membership and file server change alerts do not work as expected. This article also provides a functional workaround.
In ARM Configuration, users can add scripts to run before or after some changes. The same applies to alerts; when an alert triggers, it will run an external script. You can configure it in ARM Configuration > Scripting > Alerts. ARM also provides several built-in parameters that can be passed to the script.
Due to a known product issue, some parameters displayed in the UI are currently not functioning. Examples include:
- {AddedMemberAccounts->AccountClass}
- {AddedMemberAccounts->Count}
This behavior also affects scripting for file server change alerts.
This issue is caused by a known issue in the ARM product, where certain script parameters shown in the UI are not correctly mapped or passed to the script engine.
Use the following parameter replacements:
| Instead of using the following parameters from UI: | Use: |
| {AddedMemberAccounts->AccountClass} | {AddedMemberAccounts->AccountDetails0->AccountClass} |
| {AddedMemberAccounts->Provider} | {AddedMemberAccounts->AccountDetails0->Provider} |
| {AddedMemberAccounts->LoginName} | {AddedMemberAccounts->AccountDetails0->LoginName} |
| {AddedMemberAccounts->DisplayName} | {AddedMemberAccounts->AccountDetails0->DisplayName} |
| {AddedMemberAccounts->SecurityIdentifier} | {AddedMemberAccounts->AccountDetails0->SecurityIdentifier} |
| {AddedMemberAccounts->FullName} | {AddedMemberAccounts->AccountDetails0->FullName} |
| {AffectedPath->AccountClass} | {AffectedPath->AccountDetails0->AccountClass} |
| {AffectedPath->Provider} | {AffectedPath->AccountDetails0->Provider} |
| {AffectedPath->LoginName} | {AffectedPath->AccountDetails0->LoginName} |
| {AffectedPath->DisplayName} | {AffectedPath->AccountDetails0->DisplayName} |
| {AffectedPath->SecurityIdentifier} | {AffectedPath->AccountDetails0->SecurityIdentifier} |
| {AffectedPath->FullName} | {AffectedPath->AccountDetails0->FullName} |
Note:
- The SolarWinds development team is actively working on a fix for this issue.
- If the workaround does not resolve your situation, please open a case with SolarWinds Technical Support for further investigation and escalation if necessary
