Applications Systems
Script monitor does not provide statistic value if the script exit code is 1
The following script monitors do not provide the statistic or message output value if the script exists using the exit code 1: Windows Powershell Monitor Windows Script Monitor Linux/Unix Script Monitor
- Windows Powershell Monitor
- Windows Script Monitor
- Linux/Unix Script Monitor
See also:
SAM PowerShell Monitors are not working
