Tools
Screen share during remote session using DRE
How to share your screen with the end user during a remote session and how to reverse a session to show your Desktop to the remote user.
NOTE: This is only possible on applet sessions (attended remote support):
- Agent sessions will show [*] after the session ID in the window title
- Applet sessions will show [+] or [-] after the session ID in the window title for elevated permissions or non-elevated permissions respectively.
- Select the Remote Desktop tab.
- Select the Interactions menu.
- Press either:
- Share My Screen (View Only): Displays your Desktop/Screen to the Remote User without allowing them to interact with it.
- Share My Screen (Keyboard and Mouse): Displays your Desktop/Screen to the Remote User, allowing them to control and interact with it.
