Tools
Screen resolution problem on 4K monitor during Dameware remote connection
As there is currently no permanent fix to the issue where the remote screen displayed on a 4k monitor is very small when connected remotely to a PC, the content of this article helps as a workaround. Results may vary in different environments.
Resolution 1:
- Go to Control Panel > Appearance and Personalization.
- Under Display, click Make Text and Other Items Larger Or Smaller.
- Choose a custom setting between 100 and 500 percent.
- Set Screen Resolution to the maximum value.
- When you connect with Dameware, right-click on top of the window and select maximize.
- Adjust the toggle button to maximize.
Resolution 2:
1. Right-click on the Dameware Mini Remote Control icon on the Desktop> Properties.
2. Click the Compatibility tab> Change high DPI settings.
3. Check the box, then select "System (Enhanced)"
4. Click OK> OK.
Resolution 3:
Uncheck the "Use the MRC's Mirror Driver if available"
Resolution 4:
Select "Use the Remote Desktop (RDP)" for the machines having this issue.
