Security Compliance
Scheduled reports have stopped running in SEM
Your scheduled reports have stopped running inexplicably.
- A password may have expired.
- Your SEM was upgraded and your Reports Console was not.
Verify that you can run a report manually in the Reports Console:
- Verify that your SEM Reports Console is running the same version as your SEM virtual appliance:
- Press CTRL-A to check your Reports Console version.
- Check your appliance version under Manage > Appliances.
- Try using a different local SEM account in your Reports Console.
- Verify that the account your Reports Console is using has a password with no special characters (%, ^, $, etc).
- Verify that the report is set to the proper directory.
- If you recently reinstalled the Reports Console, you may need to recreate the scheduled report tasks as the configuration may have been lost. See Run and schedule SEM reports.
