Applications Systems
Scale DPA for the number of databases being monitored and the number of custom metrics
SolarWinds DPA is a scalable solution that can grow as your number of monitored database instances increases. You can also scale DPA for a large number of custom metrics. This article describes how to configure DPA for scalability.
11/21/2018 11:14 PM
12/18/2025 10:11 PM
SolarWinds DPA is a scalable solution that can grow as the number of database instances you are monitoring increases. You might also need to scale DPA if you configure a large number of custom metrics. This article describes how to configure DPA for scalability.
Note: Other components of your monitoring environment also need to be able to handle increased load, such as the repository database and server, the SolarWinds DPA Server machine, and the network.
Please consider having DPA in its own stand-alone environment when you have a medium to large instance count (76 and above).
Database Performance Analyzer
Adjust the following settings to configure DPA to monitor up to 250 instances:
  • Java heap settings
  • General settings in the system.properties file
For DPA 2023.1 and later, increase metrics settings in the system.properties file when DPA is collecting a large number of metrics. DPA collects a large number of metrics in either of the following situations:
  • You are monitoring a large number of instances.
  • You have configured a large number of custom metrics.
Note: Do you plan to monitor more than 250 database instances? Consider using more than one SolarWinds DPA servers and Link together separate DPA servers.
Changing Java heap settings
By default, the maximum Java heap setting is configured to monitor up to 20 database instances. To change the maximum Java heap setting, follow the instructions in this article: Increase DPA heap memory to monitor large numbers of instances.
Change the settings to the appropriate value below:
Monitored instancesMax Java heap size (64-bit)
0 - 204096 MB
21 - 508192 MB
51 - 10016384 MB
101 - 250 32768 MB
Changing settings in the system.properties file
By default, other DPA properties are configured to monitor up to 75 database instances. You can increase property settings to monitor up to 250 instances.
Note: Increasing these settings puts additional load on the repository, so increase them only if your repository has available processing bandwidth.
  1. Edit the following file:
     installdir\iwc\tomcat\ignite_config\idc\system.properties
  2. Uncomment or add the line(s) for the properties you want to change. You can cut and paste lines from later in this article. The properties and recommended values are listed in the following sections:
  3. Update each property to its new value. If multiple property entries are listed (below) for a single setting, update all property entries to the same value.
  4. Save the file.
  5. Restart the SolarWinds DPA server.
General property settings
Change these general property settings when you are monitoring more than 75 database instances. Recommended values are in the following sections:
SettingProperty entry in system.properties
Min Repo Connection Pool Sizecom.confio.idc.repositoryDataSourceFactory.minPoolSize
Max Repo Connection Pool Sizecom.confio.idc.repositoryDataSourceFactory.maxPoolSize
Trending Thread Pool Sizecom.confio.idc.services.trendExecutor.maxPoolSize com.confio.idc.services.trendExecutor.corePoolSize
Cleaner Thread Pool Sizecom.confio.idc.services.lowPriorityExecutor.maxPoolSize com.confio.idc.services.lowPriorityExecutor.corePoolSize
C3PO Helper Thread Countcom.confio.idc.repositoryDataSourceFactory.numHelperThreads
SQL Stats Connection Permitscom.confio.idc.repositoryDataSourceSemaphore.permits
DB Manager Queue Capacitycom.confio.idc.databaseManagerExecutor.queueCapacity
Values for general property settings when the repository is on a different server than DPA
If your repository has the available processing bandwidth, you can increase the following settings to monitor more than 75 database instances.
 0 - 75 instances76 - 150 instances151 - 200 instances201 - 250 instances
Min Repo Connection Pool Size10203040
Max Repo Connection Pool Size200300*400*500*
Trending Thread Pool Size10152025
Cleaner Thread Pool Size5101520
C3PO Helper Thread Count25304050
SQL Stats Connection Permits20253035
DB Manager Queue Capacity250300400500
*Make sure your repository database is capable of handling up to this many connections.
Values for general property settings when DPA and the repository are on the same server
Increase the following settings to enable DPA to monitor more than 75 database instances. Increasing these settings enables DPA to do more processing in parallel, which in turn puts additional load on the repository. Because DPA and the repository are "co-resident", increased repository load completes with increased DPA processing, and might cause DPA processing to get behind. Indications of this include:
  • The number of repository connections equals the maximum pool setting.
  • The DPA UI is unresponsive at times.
  • The DPA logs contain "Task rejected" errors.
In a co-resident situation, it is therefore necessary to limit the amount of parallel processing done by DPA. The following table shows values that either decrease or have modest increases as the number of monitored instances increases.
Note: The decreasing values shown here are guidelines, and can vary based on the processing power of the server that is running DPA and the repository. Less-powerful machines can require lower values.
Trending Thread Pool Size10152020
Cleaner Thread Pool Size5101515
SQL Stats Connection Permits20202020
Here are the lines for each scale settings needed. This can be cut pasted to the file and the needed lines uncommented.
#Scale DPA settings 0-75
#com.confio.idc.services.trendExecutor.maxPoolSize=10
#com.confio.idc.services.trendExecutor.corePoolSize=10
#com.confio.idc.services.lowPriorityExecutor.maxPoolSize=5
#com.confio.idc.services.lowPriorityExecutor.corePoolSize=5
#com.confio.idc.repositoryDataSourceFactory.numHelperThreads=25
#com.confio.idc.repositoryDataSourceSemaphore.permits=20
#com.confio.idc.databaseManagerExecutor.queueCapacity=250
#com.confio.idc.repositoryDataSourceFactory.minPoolSize=10
#com.confio.idc.repositoryDataSourceFactory.maxPoolSize=200
#Scale DPA settings 76-150
#com.confio.idc.services.trendExecutor.maxPoolSize=15
#com.confio.idc.services.trendExecutor.corePoolSize=15
#com.confio.idc.services.lowPriorityExecutor.maxPoolSize=10
#com.confio.idc.services.lowPriorityExecutor.corePoolSize=10
#com.confio.idc.repositoryDataSourceFactory.numHelperThreads=30
#com.confio.idc.databaseManagerExecutor.queueCapacity=300
#com.confio.idc.repositoryDataSourceFactory.minPoolSize=20
#com.confio.idc.repositoryDataSourceFactory.maxPoolSize=300
#Scale DPA settings 151-200
#com.confio.idc.services.trendExecutor.maxPoolSize=20
#com.confio.idc.services.trendExecutor.corePoolSize=20
#com.confio.idc.services.lowPriorityExecutor.maxPoolSize=15
#com.confio.idc.services.lowPriorityExecutor.corePoolSize=15
#com.confio.idc.repositoryDataSourceFactory.numHelperThreads=40
#com.confio.idc.databaseManagerExecutor.queueCapacity=400
#com.confio.idc.repositoryDataSourceFactory.minPoolSize=30
#com.confio.idc.repositoryDataSourceFactory.maxPoolSize=400
#Scale DPA settings 200-250
#com.confio.idc.repositoryDataSourceFactory.numHelperThreads=50
#com.confio.idc.databaseManagerExecutor.queueCapacity=500
#com.confio.idc.repositoryDataSourceFactory.minPoolSize=40
#com.confio.idc.repositoryDataSourceFactory.maxPoolSize=500
Metrics execution thread pool (DPA 2023.1 or later)
Change the following metrics thread pool settings when DPA 2023.1 or later is collecting a large number of metrics (default metrics or custom metrics). Recommended values are in the following sections.
Note: To see the default metrics that DPA collects for each monitored database type, see Metrics collected by DPA.
Core Pool Sizecom.confio.idc.metricsTaskExecutor.corePoolSize
Max Pool Sizecom.confio.idc.metricsTaskExecutor.maxPoolSize
Queue Capacitycom.confio.idc.metricsTaskExecutor.queueCapacity
Calculating property values
The values for your DPA deployment can be calculated as follows:
  • Core Pool Size (C) = The number of monitored instances.
  • Max Pool Size (M) = C * 3.
  • Queue Capacity = ((T - M) * 2), where T is the total number of metric query requests which is calculated as:
    • (C * the number of default metrics) + (C * the number of custom metrics)
Example:
If you are monitoring 75 SQL Server instances that have 52 default metrics and 100 custom metrics:
  • Core Pool Size (C): 75
  • Max Pool Size (M): 75 * 3 = 225
  • Total metric query requests: (75 * 52) + (75 * 100) = 11400
  • Queue Capacity: (11,400 - 225) * 2 = 22350
Examples of system.properties entries scaled for different deployment sizes
The following examples of system.properties entries show values scaled for different deployment sizes. These values were calculated using 52 as the number of default metrics per instance and 100 as the number of custom metrics. You can cut and paste these lines into the system.properties file and then uncomment the lines. If needed, adjust the values using the formula above.
com.confio.idc.metricsTaskExecutor.corePoolSize=75
com.confio.idc.metricsTaskExecutor.maxPoolSize=225
com.confio.idc.metricsTaskExecutor.queueCapacity=22350
com.confio.idc.metricsTaskExecutor.corePoolSize=150
com.confio.idc.metricsTaskExecutor.maxPoolSize=450
com.confio.idc.metricsTaskExecutor.queueCapacity=44700
com.confio.idc.metricsTaskExecutor.corePoolSize=200
com.confio.idc.metricsTaskExecutor.maxPoolSize=600
com.confio.idc.metricsTaskExecutor.queueCapacity=59600
com.confio.idc.metricsTaskExecutor.corePoolSize=250
com.confio.idc.metricsTaskExecutor.maxPoolSize=750
com.confio.idc.metricsTaskExecutor.queueCapacity=74500
