Sample configuration for Cisco Catalyst 6800
This article provides a sample configuration for a Cisco Catalyst 6800 switch.
This article provides a sample configuration for Cisco Catalyst 6800 series switch.
Legend:
xx.xx.xx.xxis your destination collector ( Orion)- VLAN 1 is where the data will come from (any VLAN used for management or interface will also work)
- Port 2055 is for NetFlow v9
- Port 2070 is for NetFlow v5
Below is a sample configuration for Cisco Catalyst 6800 switch. For details, see the Cisco Catalyst 6800 Series Switches home page on the Cisco website.
- Execute the following commands:
flow exporter NFexporter destination XX.XX.XX.XX source Vlan 1 transport udp 2055 ! flow monitor NFmonitor exporter NFexporter
- Add the flow records for Orion.
Note: This step can be removed if the collector accepts the data as Cisco default. Otherwise, you will need to call TAC to help you modify this part. This will only work for Cisco CAT 6800.flow record NFrecord match ipv4 tos match ipv4 protocol match ipv4 source address match ipv4 destination address match transport source-port match transport destination-port match interface input collect interface output collect counter bytes long collect counter packets long collect timestamp sys-uptime first collect timestamp sys-uptime last
- Add the flow record:
flow monitor NFmonitor record NFrecord
- Add the interfaces you need to add NetFlow to:
interface TenGigabitEthernet1/1 ip flow monitor NFmonitor input ip flow monitor NFmonitor output ! ! interface TenGigabitEthernet2/1 ip flow monitor NFmonitor input ip flow monitor NFmonitor output
