Tools
STOU FTP command
Similar to the STOR command, the STOU command is issued after successfully establishing a data connection to transfer a local file to the server. A file name is provided for the server to use. If the file does not exist on the server, it is created. If the file already exists, it is not overwritten. Instead, the server creates a unique file name and creates it for the transferred file. The response by the server will contain the created file name.
10/30/2018 10:04 AM
6/15/2020 1:33 PM
This article provides information on Store Unique (STOU) FTP command.
Similar to the STOR command, the STOU command is issued after successfully establishing a data connection to transfer a local file to the server. A file name is provided for the server to use. If the file does not exist on the server, it is created. If the file already exists, it is not overwritten. Instead, the server creates a unique file name and creates it for the transferred file. The response from the server will contain the created file name.
Common responses
