Applications Systems
SRM storage capacity attributes for NetApp DFM Cluster Mode storage arrays
Storage capacity attributes available on the NetApp DFM Cluster Mode storage arrays in Storage Resource Monitor (SRM).
10/18/2018 7:51 PM
1/27/2025 11:41 AM
The following tables show the storage capacity attributes that are available on the various storage arrays in SRM.
Storage Array
Property NameAvailable
IDYes
StatusYes
StatusDescriptionYes
NameYes
IPAddressesYes
ManufacturerYes
ModelNo
FirmwareYes
SerialNumberYes
DisksYes
VendorYes
IsClusteredNo
DeviceSyncIntervalNo
DeviceLastSyncNo
CapacityRawTotalYes
CapacityRawUsedYes
CapacityRawFreeYes
CapacityRawSpareYes
CapacityUserTotalNo
CapacityUserUsedNo
CapacityUserFreeNo
Pool
IDYes
StatusYes
NameYes
LunIDsNo
VolumeIDsYes
PrimordialNo
TypeNo
CategoryNo
ThinNo
CapacityUserTotalYes
CapacityUserUsedYes
CapacityUserFreeYes
Lun
Property Name
Available
IDYes
StatusYes
VolumeIDYes
NameYes
RaidTypeNo
ThinYes
CacheEnabledNo
ProtocolNo
ReadOnlyYes
CapacityTotalYes
CapacityAllocatedYes
IOTotalYes
IOReadYes
IOWriteYes
IOOtherYes
BytesTotalYes
BytesReadYes
BytesWriteYes
IOLatencyTotalYes
IOLatencyReadYes
IOLatencyWriteYes
IOLatencyOtherYes
HitIOReadNo
HitIOWriteNo
QueueLengthNo
Volume
Property Name
Available
IDYes
StatusYes
OwningVServerIDYes
NameYes
ThinYes
CacheEnabledNo
CapacityTotalYes
CapacityFileSystemYes
SnapshotReservedYes
SnapshotCopiesSpacePercentageYes
IOTotalYes
IOReadYes
IOWriteYes
IOOtherYes
BytesTotalYes
BytesReadYes
BytesWriteYes
IOLatencyTotalYes
IOLatencyReadYes
IOLatencyWriteYes
IOLatencyOtherYes
HitIOReadNo
HitIOWriteNo
QueueLengthNo
LunMasking
Property Name
Available
LunIDYes
InitiatorLunIDYes
InitiatorEndpointYes
TargetEndpointYes
UUIDNo
HostGroupYes
HostAliasYes
Physical Disk
Property Name
Available
IDYes
StatusYes
NameYes
SerialNumberYes
CapacityYes
VendorYes
ModelYes
TypeYes
SpareYes
FileShare
Property Name
Available
IDYes
FileServerIDYes
VolumeIDYes
TypeYes
NameYes
PathYes
QuotaYes
FreeYes
UsedYes
FileServer
IDYes
NameYes
FileServerIdentification
IDYes
FileServerIDYes
IPAddressYes
VServer
IDYes
StatusYes
NameYes
RootVolumeNameYes
VolumeIDsYes
DescriptionYes
Disclaimer: Please note, any content posted herein is provided as a suggestion or recommendation to you for your internal use. This is not part of the SolarWinds software or documentation that you purchased from SolarWinds, and the information set forth herein may come from third parties. Your organization should internally review and assess to what extent, if any, such custom scripts or recommendations will be incorporated into your environment.  You elect to use third party content at your own risk, and you will be solely responsible for the incorporation of the same, if any.
