Applications Systems
SRM storage capacity attributes for HP 3PAR StoreServ storage arrays
11/8/2018 4:00 PM
11/8/2018 4:00 PM
The following tables show the storage capacity attributes that are available on the HP 3PAR StoreServ storage array in SRM.
Storage Resource Monitor
Storage Array
| PROPERTY NAME | AVAILABLE |
| ID | Yes |
| Name | Yes |
| IPAddresses | Yes |
| Manufacturer | Yes |
| Model | Yes |
| Firmware | Yes |
| SerialNumber | Yes |
| Status | Yes |
| StatusDescription | Yes |
| DeviceSyncInterval | No |
| DeviceLastSync | No |
| CapacityRawTotal | Yes |
| CapacityRawUsed | Yes |
| CapacityRawFree | Yes |
| CapacityRawSpare | Yes |
| CapacityUserTotal | Yes |
| CapacityUserUsed | Yes |
| CapacityUserFree | Yes |
| Vendor | Yes |
| Type | No |
| Disks | Yes |
| IsCluster | No |
| Target | No |
Physical Disk
| PROPERTY NAME | |
| ID | Yes |
| Name | Yes |
| Capacity | Yes |
| Status | Yes |
| Type | Yes |
| Model | Yes |
| Vendor | Yes |
| Spare | No |
Pools
| PROPERTY NAME | |
| ID | Yes |
| LunIDs | Yes |
| VolumeIDs | No |
| Name | Yes |
| Type | No |
| Category | No |
| Thin | No |
| Status | Yes |
LUNs
| PROPERTY NAME | |
| ID | Yes |
| VolumeID | No |
| Name | Yes |
| RaidType | Yes |
| UUID | Yes |
| Thin | Yes |
| CacheEnabled | No |
| ReadOnly | No |
| Status | Yes |
| CapacityTotal | Yes |
| CapacityAllocated | Yes |
| PoolCapacityTotal | Yes |
| PoolCapacityAllocated | Yes |
| IOTotal | Yes |
| IORead | Yes |
| IOWrite | Yes |
| IOOther | No |
| BytesTotal | Yes |
| BytesRead | Yes |
| BytesWrite | Yes |
| IOLatencyTotal | Yest |
| IOLatencyRead | Yest |
| IOLatencyWrite | Yes |
| IOLatencyOther | No |
| HitIORead | Yes |
| HitIOWrite | Yes |
| QueueLength | Yes |
LUN Masking
| PROPERTY NAME | |
| LunID | Yes |
| InitiatorLunID | Yes |
| InitiatorEndpoints | Yes |
| TargetEndpoints | Yes |
| UUID | Yes |
| HostGroup | No |
| HostAlias | Yes |
| Protocol | Yes |
