Applications Systems
Enable an HPE MSA (Swordfish) array in SRM
This article contains information on enabling HPE MSA (Swordfish) arrays so they can be monitored by SRM. HPE MSA arrays communicate with SRM using a RESTful on-board API.
4/21/2025 6:21 PM
6/26/2025 1:51 PM
This article contains instructions to enable HPE MSA (Swordfish) arrays so they can be monitored by Storage Resource Monitor (SRM). Monitoring is performed through a RESTful on-board API. Use this article in conjunction with the Add your storage array for monitoring with SRM topic in the Success Center documentation.
For further information, see the documentation that came with your HPE MSA array, visit the HPE MSA support site, or contact your vendor.
N/A
SRM users can now monitor HPE MSA Gen 6 (1060, 2060/2062) and Gen 7 (2070/2073) storage arrays, which use the Swordfish API. The minimum supported firmware for HPE MSA (Swordfish) is IN210P002.
Ensure you have the following:
  • IP address or hostname for the array
  • Credential name
  • Array API username
    The minimum privileged user is monitor (read-only access). A local username is case sensitive. It can have a maximum of 29 bytes. The name cannot already exist in the system, include spaces, or include the following: " , < \ :
  • Array API password
    A local password is case sensitive. It can contain 8 to 32 characters. If the password contains only printable ASCII characters, then it must contain at lease one uppercase character, one lowercase character, one numeric character, and one non-alphanumeric character. A password can include printable UTF-8 characters, except for the following: a space or " '  , < >
  • Protocol
    The default is HTTPS.
  • API port
    The default is 443.
