Applications Systems
SRM: Enable an HPE GreenLake for Block (HPE Alletra Storage MP) array
This topic describes how to enable the HPE GreenLake for Block (HPE Alletra Storage MP) storage arrays so they can be monitored with SolarWinds Storage Resource Monitor (SRM). The GreenLake for Block arrays are monitored through REST API and SMI-S onboard providers.
1/31/2025 6:57 PM
1/31/2025 7:08 PM
This article provides information on enabling your HPE GreenLake for Block (HPE Alletra Storage MP) storage arrays so they can be monitored with SolarWinds Storage Resources Monitor (SRM). Monitoring is performed through SMI-S and REST APIs on the array.
This topic should be used in conjunction with the Add your storage array for monitoring with SRM topic in Success Center documentation, the documentation that came with your HPE GreenLake for Block array, and the HPE support site (© 2024 HPE, available at https://support.hpe.com, obtained on November 20, 2024), or contact your vendor.
N/A
HPE GreenLake for Block arrays are monitored directly through onboard REST and SMI-S APIs on the array.
Login credentials for SRM monitoring require browse permissions. To create a user with browse permissions:
  1.  Log in to the HPE Web Console.
  2. Go to Settings > Users.
  3. Click the plus sign (+).
  4. Enter user name and password.
  5. Select browse role, and click Create.
To enable the SMI-S CIM server:
  2. Go to Settings > Network Services > SMI-S CIM server > Configure CIM server.
  3. Enable Service and click Save.
Credentials required to add the array
Ensure you have the following information available:
  • IP address or hostname for the array
  • Array username
  • Array password
  • Protocol
    Default: HTTPS
Disclaimer: Please note, any content posted herein is provided as a suggestion or recommendation to you for your internal use. This is not part of the SolarWinds software or documentation that you purchased from SolarWinds, and the information set forth herein may come from third parties. Your organization should internally review and assess to what extent, if any, such custom scripts or recommendations will be incorporated into your environment. You elect to use third party content at your own risk, and you will be solely responsible for the incorporation of the same, if any.
