Applications Systems
SRM: Enable an HPE Alletra 5000/6000 array
This topic describes how to enable the HPE Alletra 5000/6000 storage arrays so they can be monitored with SolarWinds Storage Resource Monitor (SRM).
1/31/2025 7:07 PM
1/31/2025 7:11 PM
This article explains how to enable the HPE Alletra 5000/6000 storage arrays so they can be monitored with SolarWinds Storage Resources Monitor (SRM). Monitoring is performed through onboard REST APIs on the array.
This topic should be used in conjunction with the Add your storage array for monitoring with SRM topic in Success Center documentation.
For further information, see the documentation that came with your HPE Alletra 5000/6000 array, visit the HPE support site, or contact your vendor.
N/A
To start monitoring HPE Alletra 5000/6000, use the operator user role, which is the last privileged permission type for SRM.
To enroll the array, ensure you have the following information:
  • IP address or hostname for the array
  • Credential name
  • Array API username
    Array API  password
  • Protocol
    Default: HTTPS
  • API port
    Default: 5392
