Applications Systems
SRM: Enable a Huawei OceanStor Dorado array
The article provides information on enabling OceanStor Dorado V3 All-Flash Storage Systems so they can be monitored with SolarWinds Storage Resource Monitor (SRM). Monitoring is performed via an external SMI-S provider.
11/12/2018 7:52 PM
6/17/2019 9:43 PM
The article provides information on enabling OceanStor Dorado V3 All-Flash Storage Systems so they can be monitored with SolarWinds Storage Resource Monitor (SRM). Monitoring is performed via an external SMI-S provider. It should be used in conjunction with the Add your storage array for monitoring with SRM topic in the Success Center documentation or online help.
For further information see the documentation that came with your Huawei OceanStor Dorado array, visit the Huawei support site (© 2018 Huawei Technologies Co., Ltd., available at http://support-it.huawei.com, obtained on Nov 26, 2018) or contact your vendor.
Ensure you have the following information:
  • IP address or hostname for the array
  • Provider username
  • Provider password
  • Protocol. The default is HTTPS
  • HTTPS port. The default is 5989
  • HTTP port. The default is 5988
  • Interop namespace.  The default is /interop
  • Array namespace.  The default is /root/huawei
Disclaimer: Please note, any content posted herein is provided as a suggestion or recommendation to you for your internal use. This is not part of the SolarWinds software or documentation that you purchased from SolarWinds, and the information set forth herein may come from third parties. Your organization should internally review and assess to what extent, if any, such custom scripts or recommendations will be incorporated into your environment.  You elect to use third party content at your own risk, and you will be solely responsible for the incorporation of the same, if any.
