Applications Systems
SRM: Enable an HDS onboard SMI-S provider
The HDS Embedded Provider runs on the VSP (Virtual Storage Platform) of the HDS array. The VSP also hosts the Device Manager Storage Navigator or Storage Navigator management interface. This SMI-S provider is installed by default.
10/11/2018 8:43 PM
9/9/2021 6:21 AM
The HDS Embedded Provider runs on the VSP (Virtual Storage Platform) of the HDS array. It should be used in conjunction with the Add your storage array for monitoring with SRM topic in the Success Center documentation or online help.
For more information, please consult the documentation supplied with your array, visit the Hitachi Vantara Knowledge Center (© Hitachi Vantara Corporation 2017, available at https://knowledge.hitachivantara.com/, obtained on June 19, 2019) or contact your vendor.
Storage Resource Monitor
Credentials required to add array
Ensure you have the following information:
  • IP address or hostname for the array.
  • Provider username
  • Provider password
  • Protocol. The default is HTTPS
  • HTTP port. The default is 5988
  • HTTPS port. The default is 5989
  • Interop namespace.  The default is /interop
  • Array namespace.  The default is /root/hitachi/smis
Enable the array
The SMI-S provider is running on the VSP (Virtual Storage Platform) of the HDS array. The VSP also hosts the Device Manager Storage Navigator or Storage Navigator management interface. SMI-S provider is installed by default.
Enable SMI-S
  1. To enable the SMI-S functionality, the license key for this provider must be installed on the VSP.
    Open the Device Manager Storage Navigator or Hitachi Storage Navigator management interface.
  2. Go to Settings > Environmental Setting > License key.
  3. Ensure that the status of the SMI-S Provider is showing as Installed. If it is not installed, install the key from the same window. The license is available free of cost to HDS customers.
Enable the Performance Data Collection
  1. Check User Privileges Open the Device Manager Storage Navigator or Hitachi Storage Navigator management interface.
  2. Click Performance Monitor on the left side menu.
  3. Check if the Monitoring Switch option is enabled. If this is not enabled, click the Edit Monitoring Switch option.
  4. Change Monitor Switch to Enable, and select a Sample Interval (for example, 1 minute).
  5. Click Finish.
  6. Wait for the task to complete and then make sure that the Performance Monitor screen shown in step 2 has the Monitoring Switch shown as enabled.
The user account used for polling the data must be part of the Storage Administrator (View only) User Group or the Storage Administrator (View & Modify) User Group
Do the following steps to view the user groups and/or create a new user:
  1. Open the Device Manager Storage Navigator or Hitachi Storage Navigator management interface.
  2. Click Administration on the left side menu.
  3. Click User Groups and then click Storage Manager groups.
  4. Check if the user is listed in the Users section. If not, use the Create User option to add this new user.
  5. Assign the user to a single group - for example, Storage Administrator (View & Modify).
Disclaimer: Please note, any content posted herein is provided as a suggestion or recommendation to you for your internal use. This is not part of the SolarWinds software or documentation that you purchased from SolarWinds, and the information set forth herein may come from third parties. Your organization should internally review and assess to what extent, if any, such custom scripts or recommendations will be incorporated into your environment.  You elect to use third party content at your own risk, and you will be solely responsible for the incorporation of the same, if any.
Screenshots property of © 2016 Hitachi Ltd.
