Applications Systems
SQL Server long running jobs alert may fire false positives if a SQL Job was started and not allowed to finish
In DPA 9.0 and higher, the SQL Server Long Running Jobs alert may fire false positives if a SQL Server job was started and not allowed to finish.
To work around this issue, create a custom SQL alert that excludes SQL Server jobs that are started but not completed and will never be allowed to finish.
Create a new Custom SQL Alert – Multiple Numeric Return
Replace the following values in the below SQL Statement text with the values to evaluate:
- {Historical_Time_Frame} – Time frame in days used to calculate historical mean and standard deviation
Note: Ensure this is a negative in the query, otherwise it will only look to see if there are executions in the future - {Minimum_Executions} – Minimum number of job executions required in historical timeframe for job to be evaluated
- {Minimum_Job_Duration} – Minimum historical average job duration in seconds required for a job to be evaluated
The alert returns the following information:
JobName, AvgRuntime, ThresholdRunTime CurrentRunTime
LongerJob Avg:240.3333 Threshold:241.397 243
Ensure that any values configured for Alert Levels and Recipients are Less than or Equal to the {Minimum_Job_Duration} becasue how long the current execution has taken is the evaluation parameter for this (CurrentRunTime). Different jobs may have different minimums and any result should be considered abnormal. SolarWinds recommends setting a Minimum Value of 1 and no maximum value for the alert level desired from this alert.
The Notification Policy for this Alert should be set to: Notify when level is not normal
Custom SQL Alert Multiple Numeric Return
SQL Statement:
DECLARE @currently_running_jobs TABLE (
job_id UNIQUEIDENTIFIER NOT NULL
,last_run_date INT NOT NULL
,last_run_time INT NOT NULL
,next_run_date INT NOT NULL
,next_run_time INT NOT NULL
,next_run_schedule_id INT NOT NULL
,requested_to_run INT NOT NULL
,request_source INT NOT NULL
,request_source_id SYSNAME NULL
,running INT NOT NULL
,current_step INT NOT NULL
,current_retry_attempt INT NOT NULL
,job_state INT NOT NULL
--capture details on jobs
INSERT INTO @currently_running_jobs
EXECUTE master.dbo.xp_sqlagent_enum_jobs 1,''
;WITH JobHistData AS (
SELECT job_id,
date_executed=msdb.dbo.agent_datetime(run_date, run_time),
secs_duration=run_duration/10000*3600 + run_duration%10000/100*60 + run_duration%100
FROM msdb.dbo.sysjobhistory with (NOLOCK)
WHERE step_id=0 -- Job Outcome
AND run_status=1 -- Succeeded
AND msdb.dbo.agent_datetime(run_date, run_time) >= DATEADD(DD, -{Historical_Time_Frame} ,GETDATE())
-- Only jobs run in last X days
-- Job Stats (from Job History, get avg duration and avg2stdDev (threshold) filtering by job count and avg duration)
,JobHistStats AS (
SELECT job_id,
AvgDuration=avg(secs_duration*1.),
AvgPlus2StDev=(avg(secs_duration*1.)+2*stdevp(secs_duration) )
FROM JobHistData
GROUP BY job_id
-- How many runs in history need to have occurred before this alert will fire
HAVING count(*)>= {Minimum_Executions}
--Minimum length of time (in seconds) a query must have previously run to be included
AND avg(secs_duration*1.)>= {Minimum_Job_Duration} )
-- Grab currently running jobs that exceed threshold and return for alerting
SELECT
JobName=j.name + ' Avg: ' + CAST(AvgDuration AS VARCHAR) + ' Threshold: ' + CAST(AvgPlus2StDev as VARCHAR),
SecondsElapsed=DATEDIFF(SS, act.start_execution_date, GETDATE())
FROM JobHistData jd with (NOLOCK)
JOIN JobHistStats jhs with (NOLOCK) on jd.job_id=jhs.job_id
JOIN msdb..sysjobs j with (NOLOCK) on jd.job_id=j.job_id
JOIN msdb..sysjobactivity AS act with (NOLOCK) ON act.job_id = jd.job_id
JOIN msdb..syssessions sess with (NOLOCK) on act.session_id = sess.session_id -- discard jobs without a session
JOIN ( SELECT MAX(agent_start_date) AS max_agent_start_date FROM msdb..syssessions ) sess_max on sess.agent_start_date = sess_max.max_agent_start_date -- only look at the active session
AND act.stop_execution_date IS NULL -- if no stop date, then job is considered running
AND act.start_execution_date IS NOT NULL -- job must have started
WHERE secs_duration>AvgPlus2StDev -- want to grab jobs running longer than 2StdDev from mean
AND DATEDIFF(SS, act.start_execution_date, GETDATE()) > AvgPlus2StDev -- want jobs that started recently
GROUP BY jd.job_id, j.name, AvgDuration, AvgPlus2StDev,act.start_execution_date;
