Database Management
SQL Sentry Client's Performance Dashboard fails with a red bar error "No data is being collected. Please make sure the SentryOne Monitoring Service is running."
This article describes how to fix an issue with AWS instance gone offline in the Navigator Pane after being online and collecting data previously.
- No data is being collected. Please make sure the SentryOne Monitoring Service is running.
- No data exists for this range and resolution. Please zoom out or navigate forward in time.
Event ID: 7041 The SQLSentryServer service was unable to log on as <service account> with the currently configured password due to the following error: Logon failure: the user has not been granted the requested logon type at this computer. Service: SQLSentryServer Domain and account: <service account> This service account does not have the required user right "Log on as a service." User Action Assign "Log on as a service" to the service account on this computer. You can use Local Security Settings (Secpol.msc) to do this. If this computer is a node in a cluster, check that this user right is assigned to the Cluster service account on all nodes in the cluster. If you have already assigned this user right to the service account, and the user right appears to be removed, check with your domain administrator to find out if a Group Policy object associated with this node might be removing the right.
