Database Management
SQL Sentry Missing Objects or Procedures
This article goes over steps that can be taken should a target be missing some of the objects or procedures needed for monitoring.
When you watch a SQL Server with Event Manager, SQL Sentry places a few objects in MSDB that facilitate its lightweight polling architecture. No agents are placed on the server. This enables SQL Sentry to monitor the server with a performance overhead that's typically less than SQL Agent. For more information about watched server objects, see the Watched Server Objects topic.
Important: Stop watching the server through the SQL Sentry client before attempting to remove the object.
- Stop watching the SQL Server you are looking to remove the watched objects from.
- Run one of the three scripts below against the SQL Server in question (depending upon version) to delete the watched objects.
- Start watching the SQL Server in question.
SQL Server 2000 Instances:
--------------------------------------------------------------------------------------- -- Scripts are not supported under any SolarWinds support program or service. -- Scripts are provided AS IS without warranty of any kind. SolarWinds further -- disclaims all warranties including, without limitation, any implied warranties -- of merchantability or of fitness for a particular purpose. The risk arising -- out of the use or performance of the scripts and documentation stays with you. -- In no event shall SolarWinds or anyone else involved in the creation, -- production, or delivery of the scripts be liable for any damages whatsoever -- (including, without limitation, damages for loss of business profits, business -- interruption, loss of business information, or other pecuniary loss) arising -- out of the use of or inability to use the scripts or documentation. --------------------------------------------------------------------------------------- --SQL Server 2000 USE msdb if exists (select * from dbo.sysobjects where id = object_id(N'[dbo].[sp_sentry_mail]') and OBJECTPROPERTY(id, N'IsProcedure') = 1) drop procedure [dbo].[sp_sentry_mail] if exists (select * from dbo.sysobjects where id = object_id(N'[dbo].[sp_sentry_mail_20]') and OBJECTPROPERTY(id, N'IsProcedure') = 1) drop procedure [dbo].[sp_sentry_mail_20] if exists (select * from dbo.sysobjects where id = object_id(N'[dbo].[SQLSentryEmails_20]') and OBJECTPROPERTY(id, N'IsUserTable') = 1) drop table [dbo].[SQLSentryEmails_20] if exists (select * from dbo.sysobjects where id = object_id(N'[dbo].[spGetBlockInfo_20]') and OBJECTPROPERTY(id, N'IsProcedure') = 1) drop procedure [dbo].[spGetBlockInfo_20] if exists (select * from dbo.sysobjects where id = object_id(N'[dbo].[spGetBlockInfo_Pre8sp3]') and OBJECTPROPERTY(id, N'IsProcedure') = 1) drop procedure [dbo].[spGetBlockInfo_Pre8sp3] GO BEGIN TRANSACTION DECLARE @JobID BINARY(16) DECLARE @ReturnCode INT SELECT @ReturnCode = 0 -- Delete the job with the same name (if it exists) SELECT @JobID = job_id FROM msdb.dbo.sysjobs WHERE (name = N'SQL Sentry 2.0 Queue Monitor') IF (@JobID IS NOT NULL) BEGIN -- Check if the job is a multi-server job IF (EXISTS (SELECT * FROM msdb.dbo.sysjobservers WHERE (job_id = @JobID) AND (server_id <> 0))) BEGIN -- There is, so abort the script RAISERROR (N'Unable to import job ''SQL Sentry Queue Monitor'' since there is already a multi-server job with this name.', 16, 1) GOTO QuitWithRollback END ELSE -- Delete the [local] job EXECUTE msdb.dbo.sp_delete_job @job_name = N'SQL Sentry 2.0 Queue Monitor' SELECT @JobID = NULL END COMMIT TRANSACTION GOTO EndSave QuitWithRollback: IF (@@TRANCOUNT > 0) ROLLBACK TRANSACTION EndSave: GO if exists (select * from dbo.sysobjects where id = object_id(N'[dbo].[spGetJobInfo_20]') and OBJECTPROPERTY(id, N'IsProcedure') = 1) drop procedure [dbo].[spGetJobInfo_20] if exists (select * from dbo.sysobjects where id = object_id(N'[dbo].[spGetDTSLog_20]') and OBJECTPROPERTY(id, N'IsProcedure') = 1) drop procedure [dbo].[spGetDTSLog_20] if exists (select * from dbo.sysobjects where id = object_id(N'[dbo].[spQueueHeartbeat_20]') and OBJECTPROPERTY(id, N'IsProcedure') = 1) drop procedure [dbo].[spQueueHeartbeat_20] if exists (select * from dbo.sysobjects where id = object_id(N'[dbo].[spQueueJob_Start_20]') and OBJECTPROPERTY(id, N'IsProcedure') = 1) drop procedure [dbo].[spQueueJob_Start_20] if exists (select * from dbo.sysobjects where id = object_id(N'[dbo].[spQueueJob_End_20]') and OBJECTPROPERTY(id, N'IsProcedure') = 1) drop procedure [dbo].[spQueueJob_End_20] if exists (select * from dbo.sysobjects where id = object_id(N'[dbo].[spQueueMonitor_20]') and OBJECTPROPERTY(id, N'IsProcedure') = 1) drop procedure [dbo].[spQueueMonitor_20] if exists (select * from dbo.sysobjects where id = object_id(N'[dbo].[spReadLogFile_20]') and OBJECTPROPERTY(id, N'IsProcedure') = 1) drop procedure [dbo].[spReadLogFile_20] if exists (select * from dbo.sysobjects where id = object_id(N'[dbo].[SQLSentryQueueLog_20]') and OBJECTPROPERTY(id, N'IsUserTable') = 1) drop table [dbo].[SQLSentryQueueLog_20] if exists (select * from dbo.sysobjects where id = object_id(N'[dbo].[SQLSentryLogCache_20]') and OBJECTPROPERTY(id, N'IsUserTable') = 1) drop table [dbo].[SQLSentryLogCache_20] if exists (select * from dbo.sysobjects where id = object_id(N'[dbo].[SQLSentryLogCacheDTS_20]') and OBJECTPROPERTY(id, N'IsUserTable') = 1) drop table [dbo].[SQLSentryLogCacheDTS_20] GO BEGIN TRANSACTION DECLARE @JobID BINARY(16) DECLARE @ReturnCode INT SELECT @ReturnCode = 0 -- Delete the job with the same name (if it exists) SELECT @JobID = job_id FROM msdb.dbo.sysjobs WHERE (name = N'SQL Sentry 2.0 Alert Trap') IF (@JobID IS NOT NULL) BEGIN -- Check if the job is a multi-server job IF (EXISTS (SELECT * FROM msdb.dbo.sysjobservers WHERE (job_id = @JobID) AND (server_id <> 0))) BEGIN -- There is, so abort the script RAISERROR (N'Unable to import job ''SQL Sentry Alert Trap'' since there is already a multi-server job with this name.', 16, 1) GOTO QuitWithRollback END ELSE -- Delete the [local] job EXECUTE msdb.dbo.sp_delete_job @job_name = N'SQL Sentry 2.0 Alert Trap' SELECT @JobID = NULL END COMMIT TRANSACTION GOTO EndSave QuitWithRollback: IF (@@TRANCOUNT > 0) ROLLBACK TRANSACTION EndSave: GO if exists (select * from dbo.sysobjects where id = object_id(N'[dbo].[spTrapAlert_20]') and OBJECTPROPERTY(id, N'IsProcedure') = 1) drop procedure [dbo].[spTrapAlert_20] if exists (select * from dbo.sysobjects where id = object_id(N'[dbo].[spSetupAlertsTrap_20]') and OBJECTPROPERTY(id, N'IsProcedure') = 1) drop procedure [dbo].[spSetupAlertsTrap_20] if exists (select * from dbo.sysobjects where id = object_id(N'[dbo].[SQLSentryAlertLog_20]') and OBJECTPROPERTY(id, N'IsUserTable') = 1) drop table [dbo].[SQLSentryAlertLog_20] if exists (select * from dbo.sysobjects where id = object_id(N'[dbo].[SQLSentryLogData_20]') and OBJECTPROPERTY(id, N'IsUserTable') = 1) drop table [dbo].[SQLSentryLogData_20] if exists (select * from dbo.sysobjects where id = object_id(N'[dbo].[SQLSentryObjectVersion_20]') and OBJECTPROPERTY(id, N'IsUserTable') = 1) drop table [dbo].[SQLSentryObjectVersion_20] if exists (select * from dbo.sysobjects where id = object_id(N'[dbo].[fnGetSQL_20]') and OBJECTPROPERTY(id, N'IsScalarFunction') = 1) drop function [dbo].[fnGetSQL_20] if exists (select * from dbo.sysobjects where id = object_id(N'[dbo].[fnGetWaittypeDesc_20]') and OBJECTPROPERTY(id, N'IsScalarFunction') = 1) drop function [dbo].[fnGetWaittypeDesc_20]
SQL Server 2005+ Instances:
--------------------------------------------------------------------------------------- -- Scripts are not supported under any SolarWinds support program or service. -- Scripts are provided AS IS without warranty of any kind. SolarWinds further -- disclaims all warranties including, without limitation, any implied warranties -- of merchantability or of fitness for a particular purpose. The risk arising -- out of the use or performance of the scripts and documentation stays with you. -- In no event shall SolarWinds or anyone else involved in the creation, -- production, or delivery of the scripts be liable for any damages whatsoever -- (including, without limitation, damages for loss of business profits, business -- interruption, loss of business information, or other pecuniary loss) arising -- out of the use of or inability to use the scripts or documentation. --------------------------------------------------------------------------------------- --SQL Server 2005+ USE msdb if exists (select * from sys.objects where object_id = object_id(N'[dbo].[sp_sentry_mail]') and OBJECTPROPERTY(object_id, N'IsProcedure') = 1) drop procedure [dbo].[sp_sentry_mail] if exists (select * from sys.objects where object_id = object_id(N'[dbo].[sp_sentry_mail_20]') and OBJECTPROPERTY(object_id, N'IsProcedure') = 1) drop procedure [dbo].[sp_sentry_mail_20] if exists (select * from sys.objects where object_id = object_id(N'[dbo].[sp_sentry_dbmail_20]') and OBJECTPROPERTY(object_id, N'IsProcedure') = 1) drop procedure [dbo].[sp_sentry_dbmail_20] if exists (select * from sys.objects where object_id = object_id(N'[dbo].[SQLSentryEmails_20]') and OBJECTPROPERTY(object_id, N'IsUserTable') = 1) drop table [dbo].[SQLSentryEmails_20] if exists (select * from sys.objects where object_id = object_id(N'[dbo].[SQLSentryDBEmails_Attachments_20]') and OBJECTPROPERTY(object_id, N'IsUserTable') = 1) drop table [dbo].[SQLSentryDBEmails_Attachments_20] if exists (select * from sys.objects where object_id = object_id(N'[dbo].[SQLSentryDBEmails_20]') and OBJECTPROPERTY(object_id, N'IsUserTable') = 1) drop table [dbo].[SQLSentryDBEmails_20] if exists (select * from sys.objects where object_id = object_id(N'[dbo].[spGetBlockInfo_20]') and OBJECTPROPERTY(object_id, N'IsProcedure') = 1) drop procedure [dbo].[spGetBlockInfo_20] if exists (select * from sys.objects where object_id = object_id(N'[dbo].[spGetBlockInfo_Pre8sp3]') and OBJECTPROPERTY(object_id, N'IsProcedure') = 1) drop procedure [dbo].[spGetBlockInfo_Pre8sp3] if exists (select * from sys.objects where object_id = object_id(N'[dbo].[spGetQueryStatsData]') and OBJECTPROPERTY(object_id, N'IsProcedure') = 1) drop procedure [dbo].[spGetQueryStatsData] if exists (select * from sys.objects where object_id = object_id(N'[dbo].[spGetProcedureStatsData]') and OBJECTPROPERTY(object_id, N'IsProcedure') = 1) drop procedure [dbo].[spGetProcedureStatsData] GO BEGIN TRANSACTION DECLARE @JobID BINARY(16) DECLARE @ReturnCode INT SELECT @ReturnCode = 0 -- Delete the job with the same name (if it exists) SELECT @JobID = job_id FROM msdb.dbo.sysjobs WHERE (name = N'SQL Sentry 2.0 Queue Monitor') IF (@JobID IS NOT NULL) BEGIN -- Check if the job is a multi-server job IF (EXISTS (SELECT * FROM msdb.dbo.sysjobservers WHERE (job_id = @JobID) AND (server_id <> 0))) BEGIN -- There is, so abort the script RAISERROR (N'Unable to import job ''SQL Sentry Queue Monitor'' since there is already a multi-server job with this name.', 16, 1) GOTO QuitWithRollback END ELSE -- Delete the [local] job EXECUTE msdb.dbo.sp_delete_job @job_name = N'SQL Sentry 2.0 Queue Monitor' SELECT @JobID = NULL END COMMIT TRANSACTION GOTO EndSave QuitWithRollback: IF (@@TRANCOUNT > 0) ROLLBACK TRANSACTION EndSave: GO if exists (select * from sys.objects where object_id = object_id(N'[dbo].[spGetJobInfo_20]') and OBJECTPROPERTY(object_id, N'IsProcedure') = 1) drop procedure [dbo].[spGetJobInfo_20] if exists (select * from sys.objects where object_id = object_id(N'[dbo].[spGetDTSLog_20]') and OBJECTPROPERTY(object_id, N'IsProcedure') = 1) drop procedure [dbo].[spGetDTSLog_20] if exists (select * from sys.objects where object_id = object_id(N'[dbo].[spQueueHeartbeat_20]') and OBJECTPROPERTY(object_id, N'IsProcedure') = 1) drop procedure [dbo].[spQueueHeartbeat_20] if exists (select * from sys.objects where object_id = object_id(N'[dbo].[spQueueJob_Start_20]') and OBJECTPROPERTY(object_id, N'IsProcedure') = 1) drop procedure [dbo].[spQueueJob_Start_20] if exists (select * from sys.objects where object_id = object_id(N'[dbo].[spQueueJob_End_20]') and OBJECTPROPERTY(object_id, N'IsProcedure') = 1) drop procedure [dbo].[spQueueJob_End_20] if exists (select * from sys.objects where object_id = object_id(N'[dbo].[spQueueMonitor_20]') and OBJECTPROPERTY(object_id, N'IsProcedure') = 1) drop procedure [dbo].[spQueueMonitor_20] if exists (select * from sys.objects where object_id = object_id(N'[dbo].[spReadLogFile_20]') and OBJECTPROPERTY(object_id, N'IsProcedure') = 1) drop procedure [dbo].[spReadLogFile_20] if exists (select * from sys.objects where object_id = object_id(N'[dbo].[SQLSentryQueueLog_20]') and OBJECTPROPERTY(object_id, N'IsUserTable') = 1) drop table [dbo].[SQLSentryQueueLog_20] if exists (select * from sys.objects where object_id = object_id(N'[dbo].[SQLSentryLogCache_20]') and OBJECTPROPERTY(object_id, N'IsUserTable') = 1) drop table [dbo].[SQLSentryLogCache_20] if exists (select * from sys.objects where object_id = object_id(N'[dbo].[SQLSentryLogCacheDTS_20]') and OBJECTPROPERTY(object_id, N'IsUserTable') = 1) drop table [dbo].[SQLSentryLogCacheDTS_20] GO BEGIN TRANSACTION DECLARE @JobID BINARY(16) DECLARE @ReturnCode INT SELECT @ReturnCode = 0 -- Delete the job with the same name (if it exists) SELECT @JobID = job_id FROM msdb.dbo.sysjobs WHERE (name = N'SQL Sentry 2.0 Alert Trap') IF (@JobID IS NOT NULL) BEGIN -- Check if the job is a multi-server job IF (EXISTS (SELECT * FROM msdb.dbo.sysjobservers WHERE (job_id = @JobID) AND (server_id <> 0))) BEGIN -- There is, so abort the script RAISERROR (N'Unable to import job ''SQL Sentry Alert Trap'' since there is already a multi-server job with this name.', 16, 1) GOTO QuitWithRollback END ELSE -- Delete the [local] job EXECUTE msdb.dbo.sp_delete_job @job_name = N'SQL Sentry 2.0 Alert Trap' SELECT @JobID = NULL END COMMIT TRANSACTION GOTO EndSave QuitWithRollback: IF (@@TRANCOUNT > 0) ROLLBACK TRANSACTION EndSave: GO if exists (select * from sys.objects where object_id = object_id(N'[dbo].[spTrapAlert_20]') and OBJECTPROPERTY(object_id, N'IsProcedure') = 1) drop procedure [dbo].[spTrapAlert_20] if exists (select * from sys.objects where object_id = object_id(N'[dbo].[spSetupAlertsTrap_20]') and OBJECTPROPERTY(object_id, N'IsProcedure') = 1) drop procedure [dbo].[spSetupAlertsTrap_20] if exists (select * from sys.objects where object_id = object_id(N'[dbo].[SQLSentryAlertLog_20]') and OBJECTPROPERTY(object_id, N'IsUserTable') = 1) drop table [dbo].[SQLSentryAlertLog_20] if exists (select * from sys.objects where object_id = object_id(N'[dbo].[SQLSentryLogData_20]') and OBJECTPROPERTY(object_id, N'IsUserTable') = 1) drop table [dbo].[SQLSentryLogData_20] if exists (select * from sys.objects where object_id = object_id(N'[dbo].[SQLSentryObjectVersion_20]') and OBJECTPROPERTY(object_id, N'IsUserTable') = 1) drop table [dbo].[SQLSentryObjectVersion_20] if exists (select * from sys.objects where object_id = object_id(N'[dbo].[fnGetSQL_20]') and OBJECTPROPERTY(object_id, N'IsScalarFunction') = 1) drop function [dbo].[fnGetSQL_20] if exists (select * from sys.objects where object_id = object_id(N'[dbo].[fnGetWaittypeDesc_20]') and OBJECTPROPERTY(object_id, N'IsScalarFunction') = 1) drop function [dbo].[fnGetWaittypeDesc_20] if exists (select * from sys.objects where object_id = object_id(N'[SQLSentry].[SQLSentryObjectVersion_20]') and OBJECTPROPERTY(object_id, N'IsUserTable') = 1) drop table [SQLSentry].[SQLSentryObjectVersion_20]
Azure SQL Database:
--Azure
if exists (select * from sys.objects where object_id = object_id(N'[SQLSentry].[spGetProcedureStatsData]') and OBJECTPROPERTY(object_id, N'IsProcedure') = 1)
drop procedure [SQLSentry].[spGetProcedureStatsData]
if exists (select * from sys.objects where object_id = object_id(N'[SQLSentry].[spGetQueryStatsData]') and OBJECTPROPERTY(object_id, N'IsProcedure') = 1)
drop procedure [SQLSentry].[spGetQueryStatsData]
DECLARE @listOfSqlSentryTables VARCHAR(MAX)
DECLARE @sqlStatement VARCHAR(MAX)
select @listOfSqlSentryTables = COALESCE(@listOfSqlSentryTables+',' ,'') + 'SQLSentry.' +name from sys.objects where name like N'ProcedureStats%' and OBJECTPROPERTY(object_id, N'IsUserTable') = 1 and schema_id = schema_id('SQLSentry')
set @sqlStatement = 'drop table ' + @listOfSqlSentryTables
exec(@sqlStatement)
SET @listOfSqlSentryTables = NULL;
select @listOfSqlSentryTables = COALESCE(@listOfSqlSentryTables+',' ,'') + 'SQLSentry.' +name from sys.objects where name like N'QueryStats%' and OBJECTPROPERTY(object_id, N'IsUserTable') = 1 and schema_id = schema_id('SQLSentry')
exec(@sqlStatement)
if schema_id('SQLSentry') is not null
drop schema SQLSentry
