Database Management
SQL Sentry Issue with Gaps on AWS RDS Target(s) and/or Azure Managed Instance Target(s) - Message: The network path was not found.
The purpose of this article is to provide an explanation around a known issue that started with SQL Sentry Version 2023.4.3 regarding a feature flag named AlternateSqlServerCounterCollection that causes gaps on AWS RDS target(s) and/or Azure Managed Instance Target(s) while monitored by SQL Sentry.
7/5/2024 3:36 PM
2/19/2025 3:12 AM
It seems that implementing the AlternateSqlServerCounterCollection feature flag leads to gaps on the dashboard for Amazon RDS Target(s) and/or Azure Managed Instance Target(s). Gaps were observed in both the legacy (thick) client and the Portal UI (see screenshots).
Also noticed the following error stack in the rolling log:
System.IO.IOException: The network path was not found.
at Microsoft.Win32.RegistryKey.Win32ErrorStatic(Int32 errorCode, String str)
at Microsoft.Win32.RegistryKey.OpenRemoteBaseKey(RegistryHive hKey, String machineName, RegistryView view)
at System.Diagnostics.PerformanceCounterLib.FindCustomCategory(String category, PerformanceCounterCategoryType& categoryType)
at System.Diagnostics.PerformanceCounterLib.IsCustomCategory(String machine, String category)
at System.Diagnostics.PerformanceCounterCategory.Exists(String categoryName, String machineName)
at SqlSentry.Server.Windows.DataCollectors.PerformanceAnalysisDataCollector.UpdatePerformanceCategoriesByName()
Repro Steps:
  • Add an RDS Target/Azure MI Target
  • Enable the AlternateSqlServerCounterCollection feature flag using the following insert statement: insert into dbo.FeatureFlag
    (Name, Enabled)
    values
    ('AlternateSqlServerCounterCollection', 1)
  • Restart the SQL Sentry Monitoring Service(s)
  • Observe gaps and error stacks
SQL Sentry (SQLS)
Enabling the feature flag AlternateSqlServerCounterCollection will cause gaps in collection of AWS RDS target(s) and Azure Managed Instance Target(s).
If the AlternateSqlServerCounterCollection is enabled in the dbo.featureflag table, it needs to be removed.
Resolution Steps:
  1. Stop SentryOne Monitoring Services.
  2. Delete FeatureFlag with this script below if AlternateSqlServerCounterCollection exists:
    Delete
    From dbo.FeatureFlag
    Where Name = 'AlternateSqlServerCounterCollection'
  3. Restart SentryOne Monitoring Services.
As a side note: A permanent fix is set to be implemented in version 2024.3.
