Database Management
SQL Sentry Component Error: WMI
SQL Sentry encountered an error with component: Read Link Speed WMI Info' in category: Read WMI
7/14/2021 5:00 PM
7/14/2021 5:00 PM
SQL Sentry encountered an error with component: 'Read Link Speed WMI Info' in category: 'Read WMI' " error. This can be fix if the service account must have Windows admin and verify there is data in the query result set.
SQL Sentry (SQLS)
SQL Sentry component error: 'Read Link Speed WMI Info' in category: 'Read WMI'.
Step-by-step guide
  1. First verify the service account has Windows admin. If verified, run a wbemtest.exe (From the service host, using the service account creds)
  2. Click connect and type server-name(\\ServerName\root\cimv2) you are having issues connecting to then click "OK"
  3. Click query and type "SELECT * FROM Win32_Processor" also "SELECT * FROM WIN32_LOGICALDISK"
  4.  Verify there is data in the query result set. Example below:
Queries to test.
