SQL Management Studio Direct Download Link and Installation Guide
This article provides links to get SQL Server Management Studio installer without downloading SQL server as well together with the installation guide
11/1/2018 9:44 PM
8/17/2022 7:50 AM
Microsoft SQL Server Management Studio (SSMS) is the software provided by Microsoft that you can use to back up your SQL database. You can use SSMS to migrate your database to another server (back up your SQL server and then recover the database on the new server). Use the link to download the installation file, and check how it can be installed.
Orion Platform
  1. Log in to your Orion server, download the installer from the linked page and run the installer. It might take about 15 minutes to install.
https://docs.microsoft.com/en-us/sql/ssms/download-sql-server-management-studio-ssms (© 2019 Microsoft, Inc., available at https://docs.microsoft.com/en-us/sql/ssms/download-sql-server-management-studio-ssms, obtained on November 4, 2019.),
  1. How to Install SQL Server Management Studio on your Local Computer guide can be found here, (https://www.mssqltips.com/sqlservertip/4952/how-to-install-sql-server-management-studio-on-your-local-computer/ ) (content provided by Sergey Gigoyan, available at https://www.mssqltips.com/,  obtained on <August, 2021>)
  2. Follow the below article if you are not sure how to do a backup of your database.
Back up the database using SQL Server Management Studio
Disclaimer: Please note, any content posted herein is provided as a suggestion or recommendation to you for your internal use. This is not part of the SolarWinds software or documentation that you purchased from SolarWinds, and the information set forth herein may come from third parties. Your organization should internally review and assess to what extent, if any, such custom scripts or recommendations will be incorporated into your environment.  You elect to use third-party content at your own risk, and you will be solely responsible for the incorporation of the same if any.
