SNMPv3 traps not displayed in Orion Platform products
This article explains why traps do not display in the Trap Viewer for SNMPv3 devices that you configured to send traps.
To ensure that SNMPv3 traps are displayed in the Orion Web Console, review the following settings:
- Ensure that the node is monitored by your Orion Platform product via SNMPv3.
SNMPv1 and SNMPv2 work without the node being added to the SolarWinds product.
- Ensure that the polling IP address, the IP address sending the traps, and the credentials are identical. This is required for SNMPv3 traps.
- Ensure that SNMP traps are configured correctly, UDP port 162 is open, and that the same authentication type is configured for both SNMPv3 polling and traps. See Before you begin in the topic Monitor SNMP traps .
