SNMPv3 BRIDGE-MIB commands need to be added to Cisco devices for polling in Solarwinds Platfrom
New commands need to be added to Cisco switches when using SNMPv3 to expose per-VLAN values for the MIB, which UDT polls.
10/12/2018 7:35 PM
9/15/2023 1:47 AM
While everything works by default when using SNMPv2, new commands need to be added to Cisco switches when using SNMPv3 to expose VLAN values for the MIB polled by UDT.
Further explanation and information can be found in the KB article SNMP Context polling in UDT.
User Device Tracker
According to Cisco, SNMPv2 and SNMPv3 work quite differently when polling BRIDGE-MIB containing these layer 2 values.
  • SNMPv2: When asking a Cisco switch about its Bridge-MIB, you append the @ sign and the VLAN number to the community string to get that VLAN's bridging info (this is called VLAN context polling).
  • SNMPv3: There is no community string.
Do the following steps to resolve this issue:
  1. If there are devices, for example, on VLANs 3, 10, and 41 on a certain switch, the following commands need to be added:
    • snmp-server group YourGroupName v3 priv context vlan-3
      snmp-server group YourGroupName v3 priv context vlan-10
      snmp-server group YourGroupName v3 priv context vlan-41
    Another option for a command is to use the following:
    • snmp-server group YourGroupName v3 priv context vlan- match prefix
    This second command is only accepted on some Cisco devices, but it indicates to the device to match the context up to any VLAN that starts with vlan-.
  2. Depending on the configuration, the views to these commands may also need to be appended like the following:
    • snmp-server group YourGroupName v3 priv context vlan-3 read YourViewName
      snmp-server group YourGroupName v3 priv context vlan-10 read YourViewName
      snmp-server group YourGroupName v3 priv context vlan-41 read YourViewName
  3. If the customer has access lists configured that they want to apply to the authorization, then you simple add at the end the access switch with the ACL number you need
    • snmp-server group YourGroupName v3 priv context vlan- match prefix access
According to Cisco, there is no single command that will expose all existing VLANs, but a match prefix can come close to it. As these commands are added, layer 2 data should start to appear while still polling via SNMPv3.
For more information, see the following links:
Disclaimer: Please note, any content posted herein is provided as a suggestion or recommendation to you for your internal use. This is not part of the SolarWinds software or documentation that you purchased from SolarWinds, and the information set forth herein may come from third parties. Your organization should internally review and assess to what extent, if any, such custom scripts or recommendations will be incorporated into your environment.  You elect to use third party content at your own risk, and you will be solely responsible for the incorporation of the same, if any.
