SNMP or API-based monitoring for Prisma SD-WAN devices
For Prisma devices, you can poll edge nodes as SNMP nodes (with basic information polled by SNMP, and SD-WAN details polled via API), or as API-only nodes (with all details polled via API). SolarWinds recommends API-only polling when users cannot or do not want to poll nodes via SNMP. API-only polling provides less information.
2/6/2024 7:00 AM
2/10/2025 11:14 PM
For Prisma devices, you can poll edge nodes as SNMP nodes (with basic information polled by SNMP, and SD-WAN details polled via API), or as API-only nodes (all details polled via API).
SolarWinds recommends API-only polling when users cannot or do not want to poll nodes via SNMP. API-only information provides less information.
Network Performance Monitor
When you use SNMP to poll edge nodes, basic details will be polled via SNMP, and SD-WAN details will be polled via API.
When you use API-only polling for edge nodes, some basic details as well as SD-WAN details will be polled via API.
SolarWinds recommends using SNMP polling for basic details. Use API-only polling only if you cannot or do not want to use SNMP. API-only polling provides fewer details.
Polled detailsAPI-only pollingSNMP and API polling
Node detailscheck_mark_32.png via APIcheck_mark_32.png via SNMP
Node status and response timecheck_mark_32.png via APIcheck_mark_32.png via SNMP
IP addresscheck_mark_32.png via APIcheck_mark_32.png via SNMP
MAC Addresscheck_mark_32.png via APIcheck_mark_32.png via SNMP
Interfacescheck_mark_32.png via APIcheck_mark_32.png via SNMP
Further general SNMP pollingcross_mark_32.pngcheck_mark_32.png via SNMP
SD-WAN detailscheck_mark_32.png via APIcheck_mark_32.png via API
SD-WAN uplinkscheck_mark_32.png via APIcheck_mark_32.png via API
SD-WAN VPN tunnelscheck_mark_32.png via APIcheck_mark_32.png via API
CPU &  Memorycheck_mark_32.png via APIcheck_mark_32.png via SNMP
