SNMP or API-based monitoring for Meraki devices
For Meraki devices, you can poll device nodes as SNMP nodes (with basic information polled by SNMP, and SD-WAN details polled via API), or as API-only nodes (with all details polled via API). API-only polling is supported for the following device type categories: appliance, switch, and wireless. SolarWinds recommends API-only polling when users cannot or do not want to poll device nodes via SNMP. API-only polling provides less information.
10/16/2024 11:47 AM
4/16/2025 7:14 PM
Note: SD-WAN data is being polled only for appliance devices.
Network Performance Monitor
When you use SNMP to poll device nodes, basic details will be polled via SNMP, and SD-WAN details will be polled via API.
When you use API-only polling for device nodes, some basic details as well as SD-WAN details will be polled via API.
SolarWinds recommends using SNMP polling for basic details. Use API-only polling only if you cannot or do not want to use SNMP. API-only polling provides fewer details.
Polled details
API-only polling
SNMP and API polling
Node details
via API :check_mark:
via SNMP :check_mark:
Node status and response time
via API:check_mark:
via SNMP:check_mark:
IP address
via API:check_mark:
MAC Address
 via API:check_mark:
Interfaces
 via API:check_mark:
Further general SNMP polling
:cross_mark:
SD-WAN details
via API:check_mark:
via API:check_mark:
SD-WAN uplinks
via API:check_mark:
via API:check_mark:
SD-WAN VPN tunnels
via API:check_mark:
via API:check_mark:
SD-WAN VPN tunnel statistics
via API:check_mark:
via API:check_mark:
Topology
via API:check_mark:
via API:check_mark:
