SNMP and ICMP in Network Performance Monitor
NPM uses Internet Control Message Protocol (ICMP) to poll devices for response time and status, with the option of calculating node availability based on that status. Simple Network Management Protocol (SNMP) is used to poll for performance statistics. SNMP and ICMP polls are conducted on independent schedules for nodes, interfaces, and volumes, all using independent timers that are set on the Orion Polling Settings.
To configure SNMP and ICMP polling settings:
- Log in to the Orion Web Console as an administrator.
- Click Settings > All Settings.
- In the Thresholds & Polling group, click Polling Settings.
Note: ICMP timers are listed under Polling Intervals section, and SNMP timers are listed under Polling Statistics Intervals section.
Learn more:
- Troubleshoot nodes and interfaces that are unknown - learn what device status is (by default detected by ICMP) and how to address status issues.
- Orion Polling Settings - find out what configuration options and default values are available in the Orion Platform.
- SNMP in the Orion Platform
- ICMP in the Orion Platform
