Applications Systems
SMI-S Standards supported by Storage Resource Monitor
Which SMI-S Standards Solarwinds SRM supports
4/9/2019 4:47 PM
12/3/2020 6:30 PM
SolarWinds SRM data collection is fairly generic, and does not depend on the version of the SMI-S Standard in use, unless something we use has been changed and doesn't allow for backward compatibility.
For example, in the case of EMC VNX Arrays:
  • The SMI-S provider for file level storage is on the control station; any control station OS version 6.0 or more recent works.
  • The SMI-S provider for block level storage is installed on a separate machine (or as va), and 4.6.2 is the most recent version that will work.
