Security Compliance
SEM-Supported Syslog (syslog-ng) Format with Examples
This article provides information about SEM-Supported Syslog (syslog-ng) and Rsyslog.
N/
Security Event Manager also accepts syslog data from devices running the Rysylog log forwarding utility. Data logged by Rsyslog-enabled devices must be included in a file with a specific data format so Security Event Manager can read the syslog data. See Will SEM accept Rsyslog and Syslog-ng log data? for more information.
Older syslog formats sent to Security Event Manager are not supported. See RFC 3164: The BSD syslog Protocol for more information.
