Applications Systems
SAM's Linux/Unix Script monitor fails to connect on a server running OpenSSH 7.6
This article discusses an issue with SAM's Linux/Unix Script Monitor that fails to connect to a server running OpenSSH 7.6 when assigning application templates
9/17/2019 11:19 AM
12/11/2020 7:30 AM
When monitoring applications hosted on Linux/Unix machines using SAM's Linux/Unix Script Monitor, you may come across connectivity issues when the application template is assigned on machines running OpenSSH 7.6(e.g. Ubuntu 18.04).
Server Application Monitor
A bug in OpenSSH 7.6 prevents connections from SSH advertising a protocol version of "1.99" used by SAM's Linux/Unix Script monitor
Upgrade the target server's OpenSSH to at least 7.7
Workaround
  1. Change the polling method of the target server to agent
  2. Edit the application monitor to use 'Agent' as Preferred Polling Method
