Applications Systems
SAM component monitor count and licensing issues
The article explains how SAM component-based licenses work and how to manage SAM components.
After upgrading SAM, you may find that you have multiple unlicensed component monitors. If this occurs, you can either disable some component monitors, or switch to node-based licensing. See the SAM licensing model for details.
- Disable or delete components that are enabled in unmanaged applications, or
- Switch to node-based licensing. See the SAM licensing model for details.
