Applications Systems
SAM TCP port monitor is not functioning correctly
TCP port monitor is not working. Connection refused. The target actively refused connection. Port monitor failing, port monitor is down. No connection being made because target machine actively refused
5/16/2019 7:55 PM
11/30/2019 9:27 PM
This article describes potential resolutions for failing TCP port monitors. This is one of the types of components within SAM that tests an  open port. These can fail for many reasons, almost all causes are environmental network issues.
Server Application Monitor
The TCP port is blocked by the firewall.
Test connection outside of the software.
  1. RDP to the Orion polling engine assigned to the node with the TCP Port Monitor.
  2. Open PowerShell as administrator.
  3. Execute the following command. Replace <server> and <port> with the actual server hostname of the target node and the port number configured in the TCP port monitor.
    Test-NetConnection -ComputerName <server> -Port <port>
If the test fails, consult your network team for further assistance.
If the test passes, contact SolarWinds support.
Alternate solution: Try rebooting the poller on which this application monitor is not polling properly. It's possible that there's a JobEngine process holding bad run of application monitor.
