Running firmware vulnerability reports through a proxy in NCM
The firmware vulnerability resource in Network Configuration Manager (NCM) cannot connect to the National Vulnerability Database, and the resource is empty.
- Use the following procedure to set up proxy access to the National Vulnerability Database.
- On your NCM server, navigate to C:\Program Files (x86)\SolarWinds\Orion\NCM.
- Back up the SolarWinds.NCM.VulnLib.dll.config file.
- Open the SolarWinds.NCM.VulnLib.dll.config file in a text editor.
- Add the following between <appsettings> and </appsettings>, and enter the appropriate entries for the values.
<add key="proxyAvailable" value="true" /> <add key="username" value="username" /> <add key="password" value="password " /> <add key="proxyAddress" value="IP of the proxy server" /> <add key="proxyPort" value="port of the proxy server" />
- Save the file.
- Restart the SolarWinds Orion Module Engine service.
Outcome
Open the SolarWinds Orion Web Console. You can now access the National Vulnerability Database.
- Click Settings > NCM Settings > Firmware Vulnerability Settings.
- Click Run Now.
NCM tries to match your devices to entries in the database, and the Firmware Vulnerability resource is not empty.
