Routing Neighbors Resource LAST CHANGE column in SolarWinds Platform web console does not match the BGP uptime in CLI
SolarWinds Platform does not poll up/down time for BGP routing neighbors. This article explains why there's a mismatch in uptime and last change between monitored device and the SolarWinds Platform web console.
When monitoring the border gateway protocol (BGP) neighbors of a router, the LAST CHANGE column value does not match the device CLI. This article explains how the SolaWinds Platform monitors routing neighbors in the following environment.
Routing Neighbors resource
Router command line interface
SolarWinds Platform updates the LAST CHANGE column when one of the conditions is true:
- A change is detected with routing neighbor information from the monitored router.
- A new routing neighbor is added from the monitored router
Note: The SolarWinds Platform does not poll the Up and Down time for BGP routing neighbors.
The following table lists the only OIDs polled by the Orion Platform for BGP routing.
| bgpPeerState | 1.3.6.1.2.1.15.3.1.2 |
| bgpPeerRemoteAddr | 1.3.6.1.2.1.15.3.1.7 |
| bgpPeerRemoteAs | 1.3.6.1.2.1.15.3.1.9 |
