Routing Neighbor is Down alert does not trigger for EIGRP
This article discusses an issue with missed alerts configured to trigger on routing neighbors using EIGRP.
- On the web console, go to Settings > All Settings > Manage Alerts and search for 'Neighbor is down' canned alert.
- Create a duplicate and edit the alert.
- In Trigger Conditions, specify that 'Protocol Name' is equal to 'Cisco EIGRP'. NOTE: You can also use 'Protocol Name' contains 'EIGRP'
- Leave the Reset Condition as "Reset this alert when the trigger condition is no longer true"
- Complete the rest of the alert according to your preferences and then verify that the alert works correctly by simulating the email trigger.
