Applications Systems
Resource Not Found error occurs for WPM playback
Transaction for a site, for example Google.com, shows Resource Not Found but the recorder machine is able to play the recording. But during player playback, it fails and set to Down status.
11/12/2018 1:05 PM
5/12/2026 4:26 PM
Web Performance Monitor
Proxy limitation
  1. Make sure that the SEUM-UsersXXX is in Local Adminstrator status.
  2. Check  the Proxy if it is configured correctly and that SEUM-UsersXXX is able to access the site.
