Tools
Resolving SSL Certificate Issues During Renewal with Serv-U
When saving the new SSL certificate in Serv-U, an error stating "Unable to load the private key file." may appear.
Renewing an SSL certificate is typically straightforward—request a new certificate from your provider and apply it. However, issues can arise during the process, such as errors related to loading the private key file.
ERROR: Unable to load the private key file. Please make sure that the path and private key password are correct.
This error occurs due to a mismatch between the SSL certificate and the private key. The certificate must correspond exactly to the private key generated when creating the Certificate Signing Request (CSR).
Verify CSR and Private Key Match
- Confirm that the CSR used to request the new certificate matches the private key generated in Serv-U.
- If they do not match, generate a new CSR within Serv-U following the recommended procedure. Refer to the guide: Generate CSR and installing SSL certificate for Serv-U
Check Private Key Password Protection
- Determine if the private key file is password-protected.
- Try both entering the password and leaving it blank to identify the correct option.
Wildcard Certificates
- For wildcard SSL certificates, extract the certificate and private key from the PFX file before applying.
- Follow the specific steps outlined in the article: Extract SSL certificate PFX file for Serv-U
