Resetting CDR sequence numbers in VNQM
How to reset the CDR sequence cluster numbers if you cannot poll CDR or CMR data after an upgrade or reconfiguration of the Cisco Call Manager for VNQM.
After a recent upgrade, maintenance, or reconfiguration of Cisco CallManager, VNQM doesn't poll CDR or CMR data.
*Please Note: These steps will not work on more recent versions. Starting in 2022.3, VNQM no longer uses sequence numbers.
Verify the FTP location where the files are downloaded from.Verify the sequence number of the files of the following format: cdr|cmr_[clustername]_[clusterID]_[timestamp]_[sequencenumber]
Compare the sequence numbers with the contents of the CDRSeqenceNumberToDeleteFrom, CDRSeqenceNumberToDownloadFrom, CMRSeqenceNumberToDeleteFrom, and CMRSeqenceNumberToDownloadFrom columns of the VoipCcmFtpConnectionInfo database table.
If the numbers in the columns are higher than in the files, reset the numbers in the indicated columns to NULL or 0 in the VoipCCMFtpConnectionInfo database table.
-- Scripts are not supported under any SolarWinds support program or service. -- Scripts are provided AS IS without warranty of any kind. SolarWinds further -- disclaims all warranties including, without limitation, any implied warranties -- of merchantability or of fitness for a particular purpose. The risk arising -- out of the use or performance of the scripts and documentation stays with you. -- In no event shall SolarWinds or anyone else involved in the creation, -- production, or delivery of the scripts be liable for any damages whatsoever -- (including, without limitation, damages for loss of business profits, business -- interruption, loss of business information, or other pecuniary loss) arising -- out of the use of or inability to use the scripts or documentation. UPDATE VoipCCMFtpConnectionInfo SET CDRSeqenceNumberToDeleteFrom = 0, CDRSeqenceNumberToDownloadFrom = 0, CMRSeqenceNumberToDeleteFrom = 0, CMRSeqenceNumberToDownloadFrom = 0
