Report for Min/Max/Average bps In/Out graph in NPM
This is a step-by-step procedure on how to create a min/max/avg report in Network Performance Monitor.
- Log in to Orion Web Console using an account with Administrative Privilege (Admin account).
- Click Settings > All Settings > Manage Reports.
- Create New Report and choose a Custom Chart in the Resource Name.
- Click on Select and Continue button.
- Select the prefer Method in the Selection Method: (In this example we use Dynamic Query Builder).
- Choose Advanced Selector.
p
- Select Interface in the I want to report on: drop-down list.
- Set your filter for the specific Interface.
- Click on Add to Layout.
- In the Edit Resource:Custom Chart Page, Click on ADD DATA SERIES on Left Y-AXIS.
- Add the following Data Series Name: Average Receive bps, Average Transmit bps, Minimum Receive bps, Minimum Transmit bps, Peak Receive bps, Peak Transmit bps.
- Data Series should look like this in the image below:
- Click on Submit or Preview Resource.
- Back to Add Report LAYOUT BUILDER, specify the report duration in the Content Section to Last 30 days as shown in the image below:
- Click Next to proceed to Preview tab.
- Click Next to proceed to Properties tab.
- Click Next to proceed to Schedule Report tab.
- Click Next to proceed to Summary tab.
- Click Submit to finalize the Report.
NPM out-of-the-box report Min/Max/Average bps
- Reports > All Reports > Manage Reports.
- Create New Report.
- Find the out-of-the box report Min/Max/Average bits per second.
- Select and continue.
- Add Nodes or Interfaces
- Modify all your settings and follow the wizard to save the report.
