Maps or objects are not loading in the Network Atlas
This article describes how to repair the Network Atlas in the SolarWinds Platform Web Console when you see issues with it or FATAL errors in the log file.
Maps or objects are not loading in the Network Atlas. The statuses may be inaccurate as well
When you check the NetworkAtlas.log file located at C:\ProgramData\SolarWinds\NetworkAtlas\, the following error may be recorded in the log:
[Main Window UI thread] FATAL NetworkAtlas - InnerException: System.Reflection.TargetInvocationException: Exception has been thrown by the target of an invocation. ---> System.Runtime.InteropServices.COMException: Class not registered (Exception from HRESULT: 0x80040154 (REGDB_E_CLASSNOTREG))
- Log in to the NPM server as a local administrator.
- Go to:
C:\ProgramData\SolarWinds\Installers - Run
SolarWinds-Orion-NetworkAtlas.msito repair the Network Atlas.
After you run the program, a system reboot may be required.
Debug the Network Atlas
If you need to debug the Network Atlas, perform the following steps:
- Open LogAdjuster on your Primary Polling Engine (see Adjust logging levels with the Orion Log Adjuster).
- Locate the SolarWinds Information Service Section all to DEBUG.
- Increase log file size to 50 MB and 25 Files and click Apply.
- On the Network atlas (NA) machine, navigate to:
VOLUME:\Program Files (x86)\SolarWinds\Orion\Network Atlas\ - Open the
NetworkAtlas.exe.configfile. - In the file, scroll to the bottom and locate:
<level value="INFO" /> - Change the parameter to:
<level value="DEBUG" /> - Save the file.
- On your client, open the Network Atlas.
- Connect Network Atlas to the primary poller and reproduce the issue. This may require several minutes to complete.
- Close Network Atlas.
- Go to the Primary Polling Engine.
- Copy and ZIP all logs located at:
C:\ProgramData\SolarWinds\InformationService\v3.0 - Open LogAdjuster (see Adjust logging levels with the Orion Log Adjuster).
- Click Reset all to default, and then click Apply.
- On the client, open Network Atlas.
- Gather and ZIP the logs located at:
${ProgramData}\SolarWinds\NetworkAtlas\NetworkAtlas.log(any network atlas.log files) - Inspect the Primary Polling Engine SWIS V3 logs and the client's Network Atlas client logs.
- If you are contacting SolarWinds Support, be sure to provide full diagnostics with both files. (See Tips and Tricks on opening a Support Ticket with SolarWinds and How to gather and send a diagnostics file to SolarWinds Support.)
