Remove old polling engines and websites from previous migrations in the SolarWinds Platform
This article shows how to remove old engines from the Engines table and the Websites table.
10/30/2018 6:59 PM
3/17/2022 9:31 PM
When you run diagnostics on the main polling engine, you receive an error that refers to old websites and polling engines from previous installations on different servers.
Orion Platform
  • Old polling engine in the Engines table.
  • Old websites in the Websites table.
  • Duplicated entries in the OrionServers table
NOTE: Back up your database before making any changes.
  1. Open Database Manager. For details, see Use Database Manager to view the SolarWinds database.
  2. Run the query below to check for incorrect polling engines that are no longer valid:
    SELECT * FROM Engines
  3. Modify the query below to include the old polling engine ID and run the query to remove polling engines that are no longer valid:
    DELETE FROM Engines WHERE EngineID = 'YOURID'
  4. Run the query below to check for incorrect websites that are no longer valid:
    SELECT * FROM Websites
  5. Modify the query below to include the old website ID and run the query to remove websites that are no longer valid:
    DELETE FROM Websites WHERE WebsiteID = 'YOURID'
  6. Run the query below to check for incorrect Orion Server entries that are no longer valid:
    SELECT * FROM OrionServers
  7. Modify the query below to include the incorrect Orion Server ID and run the query:
    DELETE FROM OrionServers WHERE OrionServerID = 'YOURID'
  8. Run SolarWinds Platform Diagnostics to make sure the errors no longer appear when it completes.
Old polling engines, websites, and SolarWinds Platform Severs are deleted in the database.
For environments that have NTA installed.
NOTE: Create a backup of the NTA database before making any changes.
2. Run the query below to check for incorrect Flow Engines that are no longer valid:
SELECT * FROM [dbo].FlowEngines
DELETE FROM FlowEngines WHERE EngineID = 'EngineID'
