Remove unmanaged devices from Orion Web Console widgets
This article provides steps to remove unmanaged devices from the Orion Web Console widgets, formerly called "resources."
Some Orion Web Console widgets provide an option to filter displayed information selectively. The following procedure uses a SQL query to apply a status filter to a selected widget, removing information related to unmanaged devices.
Below info provides steps to remove unmanaged devices from the Orion Web Console widgets, formerly called "resources."
- Click Edit in the widget header.
- In the Filter Nodes field, type Status<>9, and then click Submit.
NOTE: 9 is the designated Status ID for unmanaged nodes in Orion.
