Tools
Remote Desktop function does not work
When an Orion Platform product user is enabled for Browser Integration (Allow Browser Integration is set to Yes), 6 icons appear on the upper right hand side on the Node Details. These icons may or may not work.
Affects IE 10 and later.
When an Orion user is enabled for Browser Integration (Allow Browser Integration is set to Yes), 6 icons appear on the upper right hand side on the Node Details. These icons may or may not work.
The following issues may occur:
- Engineering Toolset may or may not be installed on the node with the Orion server
- The Ping and TraceRoute icons will work if Engineering Toolset has been installed on the same host. See the following documents for the minimum levels needed for Active X:
- The Telnet and SSH functionality do not work on the Orion webpage, and it doesn't work on the Toolset either.
- SSH capability is available from the Management resource for the Node and does not require Toolset to be installed.
- The Remote Desktop ability will work on the Toolset (right mouse click on a node), however it does not with the icons on the Orion Node details webpage
- Microsoft closed a hole which allowed the original functionality.
- At the time of this writing, it is unknown whether these icons are supposed to call the appropriate Engineering Toolset functionality or not.
- Use SSH from the Management resource in the Node Details.
- Use the Engineering Toolset, if one is licensed for it.
Disclaimer: Please note, any content posted here is provided as a suggestion or recommendation to you for your internal use. This is not part of the SolarWinds software or documentation that you purchased from SolarWinds, and the information set forth herein may come from third parties. Your organization should internally review and assess to what extent, if any, such custom scripts or recommendations will be incorporated into your environment. You elect to use third party content at your own risk, and you will be solely responsible for the incorporation of the same, if any.
