Registered phones appear as Unregistered in VNQM
Why am I seeing the same phone appear as registered and unregistered? Why is the phone appearing as unregistered when I know it is registered?
In VNQM, the phone is marked as Unregistered on the initial CallManager when it is moved from one Cisco CallManager to another.
- Moving a phone from one CallManager to another deletes the phone from the initial CallManager and adds the phone to the second CallManager as Registered.
- VNQM does not delete the data of the phone when it is moved from one CallManager to another.
- Within VNQM, the phone is marked as Unregistered on the first CallManager and is registered on the current CallManager.
- Both statuses are shown on the Orion Web Console with the relevant CallManager.
- The phone is shown as Unregistered on the first CallManager.
- The phone is shown as Registered on the second CallManager.
