Applications Systems
Recorder Options Menu is Hidden or Blocked
Cannot click on specific options menu items. The WPM Recorder is showing hidden options in the right pane. Cannot edit inputted text on an existing Recording.
Potential workaround:
- Try to change the height of WPM Recorder window which may change the place of popup appearance and make Edit action accessible.
- Sometimes going in to "Play Action By Action Mode" changes layout and makes popup open to the bottom edge of the screen instead of the upper age.
If either workaournd is not successful, the Recording must be rebuilt in order to edit text for the time being.
