Tools
Receive Error 5: Access Denied when connecting to a remote computer using Dameware Mini Remote Control and Dameware Remote Support
This article describe the issue related to Error 5: access denied and resolution.
10/7/2018 10:06 PM
3/4/2022 1:53 PM
When attempting to connect to a remote machine using Dameware Mini Remote Control, you may receive the following error: Error 5: Access Denied when connecting to a remote machine with Dameware Mini Remote Control.
This also happens when you access certain functions on the DRS (e.g. Processes and Services), you'll receive an "Access is Denied Error 5" and the remote host details you were looking for would not load.
Dameware Remote Support & Mini Remote Control
You do not have the proper credentials to log onto the remote machine. The credentials you use to connect must be a member of one of the following groups on the remote machine:
  • Administrators
  • Power Users
  • Server Operators
  • Account Operators
  • Backup Operators
  • Print Operators
To resolve the issue:
1. Press Shift and right-click the Mini Remote Control icon.
2. Select Run as different user and provide the admin credentials used to install the Dameware agent on remote machines.
Once the agent has been installed, you can run Dameware normally and then connect again to the remote machine.
Please also check for DWMRCS entries in the Application Event Log on the remote machine for details about why you were denied access.
