RabbitMQ installed on Additonal Polling Engine or Additional Web Server
Orion Service Manager shows up RabbitMQ service existing on Scalability Engines.
Orion Platform, during upgrade, also upgrades RabbitMQ but only on the Primary Polling Engine, hence versions installed on the Scalability Engines may differ.
It may also come as a component of some other application installed on the same server as Orion Platform modules, and its version may also differ from the one installed on the Primary Polling Engine.
If it is required by other application additional consideration has to be put in place, including moving colliding application to a different server.
