RAM and CPU Data not available for ASA
This article describes how to troubleshoot the 'No Data Available' of RAM and CPU widget for ASA
3/3/2020 5:17 PM
3/27/2020 3:26 PM
How to check 'No Data Available' of RAM and CPU widget for ASA.
Network Performance Monitor
Check the following.
1. Go to node > Click List of resources
Make sure that CPU and memory is checked.
2. Test SNMP if its successful. If not, check the credentials
3. Delete then re-add the widget
Go to Nodes details > click the pencil icon on the upper left corner of your dashboard > Add widget
Search for RAM and CPU > then add widget
