Applications Systems
Python Examples for Unix or Linux monitor on Linux
This article includes an example of a Python script that returns constants and an example of a Python script that will print the value of a variable. These are running on SAM 6.6.1.
Here are sample Python scripts. These are running on SAM 6.6.1.
1. Here is an example of a Python script that returns constants:
print ("Statistic.Stat1: 1");
print ("Message.Stat1: Hello World");
Output Result:
Statistic.Stat1: 1
2. Here is an example of a Python script that will print the value of a variable (the variable, value, is an integer):
#!/usr/bin/python
import sys
value = 20
print "Statistic.Stat1: %d" % value
print "Message.Stat1: hello World"
sys.exit(0)
Output Result:
Statistic.Stat1: 20
